Installing Mirrors with Turn Signal Repeaters
Stock mirrors on motorcycles are often made of plastic, lack full adjustment and secure joints, but are very expensive. Finding a better-quality alternative for less money is no problem. For example, German Torezzo mirrors with an aluminum housing and stem have three adjustments and bright LED turn signals, and all the joints are made of stainless steel. Fitting the mirrors in the standard mounts isn't hard; the main problem is connecting the turn signals without modifying the stock wiring. Special tap connectors are handy for tapping in. They can be taken apart and don't require cutting, stripping or soldering wires.
It's important to measure the wire thickness and choose the matching tap connector. If you choose the wrong size, you can cut the stock wire or there may be no contact. As a rule, the turn signal wires are thinner than the wires in the harness. To ensure reliable contact with a thin wire, it's best to strip it and fold it over: there will be contact even if the clamp doesn't pierce the insulation!
It's advisable to put heat-shrink tubing on the mirror wires: it will protect them and bundle them into a harness. It's better to heat the heat-shrink with a heat gun: thin heat-shrink is easy to burn with a lighter. It's best to tap into the motorcycle's wiring before the stock turn signal connectors, so they can be removed without disconnecting the mirror repeaters.
In the video we showed how to install Torezzo mirrors with turn signal repeaters on a 2014 Kawasaki Z1000.
