Stunt Bike Review: F4i, ZX6R, R6, CBR, GSXR
These motorcycles were chosen based on statistics from international stunt forums. Motorcycles from European brands are not included in the review, since they are less popular because of high prices, although they are also excellent bikes ridden by well-known pro riders.
HONDA CBR F4i
A classic motorcycle. The most popular stunt bike in America along with the ZX636. The F4i's reliability and durability are legendary. The F4i is the motorcycle best suited for stunts and the best option for beginners. It's almost impossible to kill.
Pros:
- Reliable engine.
- Strong frame.
- Strong subframe. No reinforcement needed.
- The oil starvation problem is easily solved: a special baffle is fitted in the engine crankcase.
- Cheaper than the competition. But this doesn't apply to Russia. When people understood what this motorcycle is good for, prices shot up.
The motorcycle has no real cons. Mike Jensen became world champion on an F4i in 2018; his runs are on our channel. Pawel Karbownik has competed at the top level for several years, is a multiple world championship podium finisher and has always ridden an F4i. So as cons we will list the parameters in which the bike falls behind the competition, but that doesn't mean it's bad.
Cons:
- Power. The F4i is a bit weaker than the competition.
- Weight. Slightly heavier than the competition.
- The F4i hasn't been updated since 2001. It is becoming outdated in design and technology: a conventional fork, non-radial brakes.
KAWASAKI ZX636 Ninja
A direct competitor of the F4i. The most popular bike among pro riders. Just watch any professional competition to see it: 60% of pro riders ride Kawasakis. The 03–04 model stands out in particular. Not the best option for beginners: the 636 won't survive a serious crash. The 05–06 model is also very popular, but newer motorcycles are used only by pro riders, since over the years all sport bikes become more fragile, and Kawasakis especially.
Pros:
- Excellent, smooth low-end drive.
- No oil starvation problems. Overfilling the oil is enough. Many don't even overfill, and everything is OK.
- Probably the lightest. Agile.
- Strong stock subframe.
Cons:
- The frame is weaker than the competition's. Not the best option for beginners. On the stock frame you can only ride with a shock-absorbing cage, for example the Stuntex Mad Dog cage.
- Not the most reliable engine. Problems really do occur often, but the motorcycle's popularity has to be taken into account. Obviously, the more motorcycles, the more problems. You can't say for sure that the engine is less reliable than the competition's.
YAMAHA YZF-R6
This motorcycle is gaining popularity. The reason for the growing interest is that solutions to the subframe problem have appeared. It was because of the subframe that the R6 wasn't popular with stunters for a long time. Only recently have well-known stunt brands started making steel subframes for this motorcycle. Now many pro riders ride the R6, preferring it to Honda and Kawasaki.
Pros:
- Powerful engine with excellent low-end drive.
- Light. Agile.
- No oil starvation problems. Overfilling by 0.5 liters of oil is enough.
- When properly prepared, a very strong motorcycle.
Cons:
- The subframe is unfit for stunts. Replacing the subframe will cost a pretty penny.
SUZUKI GSXR600
Suzuki was one of the first to release fuel-injected 600s. Models before 2003 were very popular as stunt bikes, since the competition had nothing similar. Honda had the F4i, but it was positioned as a sport tourer, while the Gixxer was a pure sport bike. When the competition came out with similar bikes, the GSXR's popularity dropped sharply. Gixxers started falling behind in many ways. Today there are practically no pro riders on Gixxers. Motorcycles of this series have fans, but they are usually not beginners and treat the bike carefully.
Pros:
- Many like the Gixxer's explosive character. There is a model with a 750 cc engine. The engine is very lively, pulls great from the bottom and doesn't let go until the rev limiter.
- Nothing bad can be said about the engine. There have been cases of engines seizing, bearings cracking and pistons burning out, but no more often than with the others.
- There is a very good solution to oil starvation. It is sold on eBay.
Cons:
- The frame is very weak. It sometimes cracks near the steering head on hard landings from wheelies. A very serious drawback, so beginners shouldn't buy one, and neither should anyone else.
HONDA CBR929/954
The 929/954 Fireblade was a very popular stunt bike in the past. Today no pro rider uses this motorcycle in competition. But it's a decent option for learning. First, it will be relatively inexpensive (production ended in 2003). Second, it is the toughest and strongest of them all.
Pros:
- Very reliable. Strong frame and subframe. An indestructible engine.
- No oil starvation.
Cons:
- The one drawback is that it's a liter bike. Heavier and bigger than the competition. You get tired faster in training. Less maneuverable. Harder to handle at low speed.
- Outdated: not a single pro rider competes on an old Fireblade.
HONDA CBR600RR
The most controversial motorcycle. A Honda is a Honda. Honda always means quality and reliability. The motorcycle is truly trouble-free in the city and on the track, but not on the lot. Probably the least successful stunt bike of all those presented. There are only a handful of pro riders on the RR, but they exist.
Pros:
- It's a Honda. A plus for all fans of the brand. The engine is probably more reliable than Kawasaki's and Suzuki's.
Cons:
- The frame handles sideways crashes poorly. Even cages from leading manufacturers don't prevent cracks at the engine mounts.
- Weak low-end drive.
- Engine problems occur very often. It overheats a lot in stunt mode. Owners constantly deal with the temperature problem.
In conclusion, I would like to note that this comparison is quite relative, since the quality of stunts doesn't depend on the motorcycle. These motorcycles are popular not because tricks are easier on them, but because they are better suited to training: crashes, loads and wear. The difficulty of doing tricks on all sport bikes of a certain class, as well as neo-classics built on them, is the same and depends entirely on the rider's skill or lack of it.
