GPR V4 Rotary Damper Repair
A steering damper (stabilizer) is a necessary setup for stunt riders who actively practice stoppies. Rotary dampers are more popular than linear ones, because they are more compact and easy to remove and install, which matters a lot with frequent repairs. In principle all rotary dampers are built the same way and require the same servicing as a fork or shock. Manufacturers recommend changing the oil every two years and repairing the damper if the joints leak. The repair consists of cleaning and replacing all seals (O-rings) and the oil.
For GPR dampers the rebuild kit consists of a set of O-rings of different diameters and a retaining ring. Fork oil of different viscosity is used depending on the riding conditions and loads. At the factory GPR fills 5–10W oil. It is recommended to increase the oil viscosity if the damper is used at above-average settings.
We used 10W, and the damper worked perfectly for a city motorcycle or stunt bike. Dampers with a wide adjustment range, such as Scotts dampers, use low-viscosity oil: 2.5–3.5W.
Disassembling the GPR V4 damper isn't hard, but keep in mind that American brands use bolts for inch hex keys, so you will have to buy the tools. After disassembly, drain the oil and clean all parts with kerosene. During assembly, lubricate the new O-rings of the moving parts with oil. After assembly the damper is filled with oil. This must be done so that no air gets into the system. Air is easy to feel if you close the filler holes and move the lever in different directions: at the end of its travel the lever will drop, and you will hear bubbles.
Important: In hot weather the oil may seep, as it expands and is pushed through the O-rings. Oil can also seep due to prolonged intense loads, for example during training on a track or lot. In this case it is recommended to periodically check the system for air and top up the oil as needed.
