Tight Figure Eight on a Sport Bike
A guide to a basic low-speed control element on a sport or street motorcycle: the tight figure eight. Useful for all beginner riders!
The tight figure eight is a basic exercise that trains low-speed motorcycle control, which is very useful for turns, U-turns, riding in confined spaces, traffic jams and so on. That is why this exercise is part of the practical exam.
Most riders take the figure eight on light street motorcycles. This is very easy, since such motorcycles have a large steering angle and a short wheelbase. Thanks to this, the figure eight can be ridden at idle with the handlebar turned to full lock. This method doesn't work for sport bikes and other big motorcycles. Because of the narrow steering angle, the motorcycle has to be leaned into the turn, which is hard to do right away at low speed. The easiest way to do it is counterweighting.
The idea is to create a counterweight to the motorcycle, which tends to fall over at low speed. The video shows everything clearly! Besides counterweighting, you need to control the drive. You can control it with the rear brake and the clutch. The brake is convenient in the circle, and the clutch on the exit. If the motorcycle starts to tip over or stall, give it some throttle. But don't dump the clutch, because the rear wheel can break loose into a drift. To have time to switch the motorcycle to the other side where the circles meet, just pull the clutch: the motorcycle will slow down, but you can give it some throttle to enter the next circle at speed.
