48mm Fork Oil Seals Replacement
Turn on English subs.
Here is the proper way to rebuild Kayaba fork and change oil seals. This fork is used on many motocross and enduro bikes: CRF250, CRF450, YZ125, YZ250, YZ450, WR250F, WR450F, KX450F, KX250F, RMZ250. The procedure is not complex but needs special tools and time. If you do everything right, the fork will last for a long time.
