Coolant Change Yamaha WR450F
It is recommended to change the coolant on the Yamaha WR450F as needed or every two years. This is because the motorcycle runs at maximum loads with poor cooling due to low speed and mud getting on the radiator. Dust also gets into the system through the overflow hoses of the expansion tank, at the bottom of which dirt always collects. The replacement procedure is very simple and shown in detail in the video. Flushing the system with distilled water is recommended at every coolant change. Any ethylene glycol antifreeze for aluminum engines is suitable.
