Oil Change Yamaha WR450F YZ450F
The oil change procedure for WR450F and YZ450F 2021 is the same. In the video, we changed the oil as the owner’s manual says. But you can make it simpler: just remove the overfill check bolt and fill the oil until it spills out — in this case, there is no need to check the oil level after the procedure.
Stuntex T-shirts & Hoodies: stuntexru.myspreadshop.net/all
WR450F 2021 uncorking: Uncorking Yamaha WR450F 2021
Oil Change WR450F YZ450F 2021 Magazine Ouest Bike Show 2023 Supermoto Mayhem 2 Magazine Piston Replacement CRF450R
