Installing XSR900 Sliders
It makes sense to fit motorcycle protection when there is a higher risk of crashing, for example during training, during long-term use in difficult road conditions or during extreme riding. In a slide, sliders protect the main, most expensive components: the frame, swingarm, engine crankcase and fork, whose replacement costs about as much as the motorcycle. In a collision with an obstacle, side protection also saves a little on repairs, but doesn't fundamentally change the situation.
The XSR900 is a designer neo-retro motorcycle, so looks matter a lot for such a bike. We decided to fit sliders only because we plan to film training videos that involve extreme riding.
LSL makes a full set of sliders for this motorcycle. There are two types of engine sliders: with a two-piece bracket on two mounting points, and without a bracket, in the front engine mount. We chose the bracket version.
When fitting engine sliders, it's very important to observe the fastener tightening torques, since the fasteners are steel and the mounting points aluminum. First, you can damage or strip the thread in the engine with excessive force. Second, an overtightened bolt is under tension and will break sooner under load.
It's also important to do everything according to the instructions and measure the components before fitting, because the kit may contain bushings and spacers that look identical but differ in length by half a millimeter. Incorrect bracket assembly puts extra bending load on the fasteners and greatly reduces the strength of the structure.
Correct slider installation guarantees that all mounting points stay intact in an unusual impact, for example hitting a curb: in such a case the brackets and bolts should break without transferring energy to the frame lugs and into the engine.
Magazine SX Racer Cafe Racer Is Ready! Magazine German Stunt Week 2023 Best Harley Sportster Stunts Magazine Piston Replacement CRF450R
